TGCZ 2.5" level under strut
I have not seen any bottom spacers that are over 1". Most leveling kits that are over 2" (Readylift 2.25", CCM 2.5", TGC 2.5") all utilize a top spacer or a combination of top and bottom spacers
i have a 2.5" in mine (over the top of the strut though) and so far its fine. your ride is going to be a lot tighter. Its almost as rough riding as my t/a with stiffer suspension parts. Although you're putting a block under the strut you're essentially extending the strut beyond its OEM resting point for its life, so i've heard the struts may go quicker as well as all the front end components.
and yes they do make a 3" block, and from what ive heard, it takes no time to trash all the front end parts
Coworker of mine has the rc 2.5 kit in his 08 ecsb sierra and the angles are fine. Not to mention he let me drive it around the block when I finished putting it in (first time ever inside an nnbs :lol: ) and it rode like a car on 285 60r18 terra graps.
hmmm....i wonder what it could be then. i have a crew cab short bed not a z71 pack. I put the 2.5" leveling kit on, took it for a spin and could feel the suspension being tighter. once i put on my KM2's then it got a bit rougher too cuz of the stronger sidewalls. I'm not complaining, my second car ever was a 87 t/a (which i still have) and that has a rough ride! this truck is a little stiffer than stock but just not the cadillac it used to be lol
Most of it is probably the terra graps. Plus like I said it was my first time in an nnbs so maybe what I think is a smooth ride is rough to y'all :dunno: after all I am riding around on 305 buck shots as a comparison :lol:
Sent from my SGH-I927 using Tapatalk 2
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
