'radio push buttons falling apart on 1999 silverado 1500'
Radio push buttons falling apart on 1999 silverado 1500' Anyone know where I can get the four push buttons?
Thanks for the reply. It's a tape deck model and there are are four push buttons for Fade, Bal, Bass, & Treb. The buttons just push in to extend so you can turn them. They just pull off. Two have just fallen to pieces. One has a crack in it. They're very small between the scan and the clock set.
Radio
Okay those can be purchased cheaply from your local GM dealer.
PN# 16195412. They list or $12.66 each +tax.
Is she a 1999 "classic" or a NBS 1999??
:happysad:
Not that it matter at this point but for future referance the 99 "classic and 99 NBS had the same exact radio
1995-2002 trucks all used this same radio tape or CD
You can get them on eBay for $9.50 each....I'd replace the radio w/ another factory radio or aftermarket style.....that's fricking ridiculous.
9.50 for a little piece of plastic?! haha
Sounds like the lug nut covers on my truck. $7 at the dealer, $2 something at auto parts store.
Thanks guys. Not the right ones on ebay, Dorman, Advance Auto. Going to the junk yard. :nonod:
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
