Getting my A/C working again.....
07sierra8.1
Ok so first let me give you an insight to what the set up is....
The Truck is a 1986 Chevy K20, truck did not come from factory with A/C when the truck was restored, the whole a/c system from a 1981 Chevy K10 was put in my K20 the truck hasn't had the a/c working in about 3-4 years, while my father still had the truck the compressor went bad leaking all the r-12 out slowly till it was all gone. Since then the system has been dry. I have a new compressor and a R134a Retro fit kit.
Truck has the R4 "Heavy" Compressor on it
Here was my plan, I just wanted to run this by you guys to make sure I am covering all my bases and not going to have to Go back and redo things.
1)Add Proper amount of oil to new compressor
2)Reinstall compressor
3)Replace Acuumulator/Drier & Orfice
4)Replace all accessible O-Rings with 134a tolerant ones
5)Pull a vacuum on entire system
6)Recharge System with 134A
Now for the questions-
Did I miss anything?
What kind of Oil should I use in compressor?
Which port on the compressor does the oil go in?
How much should I add to accumulator/drier?
Usually the compressor says how much oil to add. I would add oil to the compressor on the "inlet" port. Does your "retro" kit come with a new condenser? R-12 condensers don't provide the heat transfer like parallel flow condensers made for 134a
no it doesnt :/....and the old compressor says 6oz of oil, and from what I have read on other threads, ester oil works best for vehicles that are retro fit to 134a??
Also not sure if this is true or not, but my ex girlfriends father who works at a garage that is commonly known for doing good a/c work told me along time ago to NEVER add any refridgerant with any kind of sealer in it...that over time the sealer gums up and makes components fail?
I am asking this cause the retro kit came with 4 cans of 134a with sealer in it..and I was gonna just gonna go buy regular 134a with no sealer instead of using what came in the kit.
You got some EXCELLENT advice on the sealer. Don't use it .... EVER ... unless your junking the vehicle in a few weeks. The stuff turns to concrete upon prolonged contact with air, rendering every part of your system useless when opened up for repairs. Not to mention clogging thousands of dollars worth of shop equipment ...
Here's what I do: Take the new compressor, and FLUSH it out thoroughly with the ester you plan to use, EVEN IF it came tagged that it was full of oil already. Turn it over by hand to pump it out, then fill again until the oil coming out is SPOTLESS. Flush out the lines and evaporator with acetone or brake cleaner, then blow COMPLETELY dry with compressed air. You need the spec for the entire amount of oil for the system - say 8 oz. - then put a couple oz. in the accumulator, 4 oz. in the compressor, then an ounce or so in the condenser. Button everything up, vacuum for 5 minutes, then let it sit for 15 minutes or so and check for leaks, then vac again for at least a half hour - the longer the better. This will boil & remove any moisture that may have been introduced by the compressed air. I've never had a failure doing this in over 10 years.
If it were me, I'd have left it R12, as it is a MUCH better refrigerant in so many aspects ... but if that's too spendy ... (I'll probably get excoriated for mentioning this) ... but good ol' CHEAP propane (R290) works even better than R12 if you can believe that one. Not as clean as the pure R290 in Europe, but it works. But since you've already got the conversion kit (o-rings and fittings?) & refrigerant, might as well run with it. Get a parallel-flow condenser as big as you can fit in front of the radiator for 134a.
Yep, stay away from sealers....
8 oz looks like the amount. I use ester oil with dye. PAG or Ester, whichever you use, keep tightly capped before and after use. They both readily absorb moisture from the air.
    • He does, actually. In another unrelated video he mentions the president called him in the middle of the night to relay some information on a cause (religious based) that he's invested in. Glenn expressed concern that another leftist administration could wield too much power with some procedure the Pentagon was using, classifying certain religions a certain way. Being that he is LDS (Latter Day Saints), he gets hate all the time from ALL over the political spectrum, so he's invested in this. Trump called him back at 5AM to tell him he had made some changes to that classification.   So, yes, they are and have been in contact regularly since the start of the administration. Glenn, of course, always asks his permission before discussing anything on the air.   I already spent an hour or more just searching for these videos. I may have my numbers wrong - I'm not a numbers guy. It may have been a MILLION barrels, not 1.5. The point is, our President, by his actions, gives a crap about America, and US - this is completely OPPOSITE the actions of the prior administration who projected hatred for anyone who wasn't following the left's edicts in lock-step.   Remember, they called January 6th an "Insurrection", when there were ZERO weapons among the crowd, undercover FBI agents agitating the crowd, along with paid leftists acting as aggressors, egging the crowd on in an attempt to whip everyone into a frenzy. It's all been proven.  Pelosi refused Trumps request for more National Guard troops. This smells 100% like an inside job for those with critical thinking skills. Only a handful of guys in the crowd got wrapped up in that, thankfully, but EVERYONE was searched out based on cell phone data, and charges were brought against many. And 6 or so people were locked up and left in solitary confinement for YEARS with ZERO due process!! If you give the slightest crap about our Nation, REGARDLESS of your political leanings, this should frighten you to your core. This is what men suffered, bled, fought, and died against 250 years ago!   This has gone FAR BEYOND left vs. right. This is a  threat to America, and our way of life. This is PRECISELY why Trump, a BILLIONAIRE who could have chosen to take Melania and sit on some tropical island that he could afford to buy himself and RELAX, instead chose to run for office, get hate from literally every corner of the media, get ATTEMPTS on his LIFE constantly, and begin to repair some of the severe damage that's been done to this Great Nation.   I don't know why I bother wasting my precious time here. Everyone has their minds made up. They won't realize we all were correct until it's too late ... after they elect another tyrant that hates America to office (Obama), or another puppet whose administration is secretly running the show behind the scenes (Biden).
    • Hello, Im in a bit of a bind maybe someone could help me out.  We towed our trailer, up a pretty steep incline (395 north of Bishop) done it before no issues. I got to our campground turn truck off, i restarted the truck about an hour later  and check engine light turns on. Found DTC P2C48,  unable to reset.  This morning i removed the plug, there's 12.12v at the plug. Reservoir near firewall is full of coolant, checked for leaks nothing. I dont hear or feel the pump turning on. My dilemma, is nearest dealer  is 4hrs away that has the pump instock. Is it safe to drive? By me checking the available voltage at the connector and not hearing/feeling pump turn on, is it a bad pump? Please help...
    • The figure bandied about is "100 million barrels" so I think a decimal is off somewhere. But that doesn't change the outcome much when the expected flow through the Strait through over the same time should have been more than 2,000,000,000.   So 5%, if that number is even true, and there's sufficient data to believe it's not. Give that man another Fifa peace prize! 5% is less than the flow of a grapefruit-sized prostate blocking the release of cheap lager after a night of bingo.
    • 1,500,000 barrels of oil would run a Class 1 refinery for about 3 days.    You guys are deep into where the ants on the boat came from as the Titanic is sinking.    😏
