I have a 06 GMC 2500HD 4x4 6.0 4L80E 4:10.. 85,500 milage.....
my issue is the torque converter will unlock at random at about 70 mph.
I can pull a trailer with a heavy load and stay under 70 mph and all is great. power is good. however with NO load and level ground the torque converter unlocks and will not lock back up until I slow down to below 65 mph.
NO CODES.....
I have extra parts from other trucks to which I have changed the throttle position sensor, throttle body, ECU on the firewall under the hood, and the torque converter lock up in the trans. also changed the fluid, added lucas all with no change.
it takes it a long time to lock up when its cold, first thing of a morning.
this truck does great under a load or empty as long as I stay below 70 mph.
using the cruise or with out, no change.
any suggestions as to where to look and what at would be great.
@ about 75000mi I had problem with my tranny over heating. I had to have the TC replaced, along with all the lines too. They told me it was common with 4l80e
I have owned it since 45,000 miles......I never drove it on the interstate or got above 70 until a year ago.
the temp guage never gets hot, trans seems to run cool. I replaced the stock cooler with a larger trans cooler.
it does this when its cold also. first thing of a morning takes a long time for TC to lockup.
I had a similar issue with my 4l80e. Put a larger cooler on it and the same thing happened.
There is a temperature sensor in the transmission. When the trans fluid goes below a certain temp, torque converter lockup is canceled. When the temp goes above that temp, it is re-enabled.
When your torque converter is in lockup mode, the transmission is in a "cooling and overdrive planetary lube" mode.
With the larger cooler it is going below the temperature range that allows this when in lockup.
Not going into lockup with the 4l80e due to over cooling will not damage anything. It will just affect your mpg.
I had a similar issue with my 4l80e. Put a larger cooler on it and the same thing happened. There is a temperature sensor in the transmission. When the trans fluid goes below a certain temp, torque converter lockup is canceled. When the temp goes above that temp, it is re-enabled. When your torque converter is in lockup mode, the transmission is in a "cooling and overdrive planetary lube" mode. With the larger cooler it is going below the temperature range that allows this when in lockup. Not going into lockup with the 4l80e due to over cooling will not damage anything. It will just affect your mpg.
what ?,where did ya get that info ? i must check my blue book if i can find it lol
Edited by govtech4
Oh just being a transmission specialist / rebuilder for well over a decade.
Mine always unlocks on hills, pulling or not.
Scooby
Hot or Cold.....
Edited by scooby5121
Yeah but locking and unlocking at random is not normal. The most annoying thing I found was the wide open throttle lockup in 2nd gear that the 80E's do.... dumb. So neither of mine have that ability anymore lol.
I was convinced my 04's transmission was toast. My convertor would lock and unlock at random.... wouldn't unlock properly etc. Then the trans itself shifted really hard ( line pressure was maxing), hang up in gears etc... I had no codes, nothing that really stood out. So because I have parts I swapped the 3 things one at a time enginewise I thought it could be, being my throttle body ( so I got a known good tps), map sensor and MAF sensor. Low and behold it was my MAF... Now I have scanning software and I had very odd fuel trims at idle, random knock retard at WOT etc. The truck ran well enough and never did anything weird that without seeing the data no one would have noticed the engine issues ever.
It's worth a look anyhow. I have had a check engine light or anything either, and if the OP has parts to swap since you tried the throttle body give the mass airflow and map sensors a try.
I didn't have the exact same symptoms as you but mine would lock then unlock and not lock again on the highway. Did some reading on this site and the solution to mine was a crank position sensor relearn. Did they with a SnapOn scanner believe it was a Modus and all is good now.
NO CODES.....
I have the same truck same mileage and I had the same problem 6 months agohad to have the dealership replace a torque converter and all the lines going to the raditormy issue was is that the transmission was overheating
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
