Can folding mirrors get broken?
I have an 09 Chey 1500 Ext. Cab with the electric folding mirrors. Sometimes I fold the mirrors in while in the driveway at home.
I noticed sometimes when I take the truck to the carwash, the mirrors are folded.
I don't know if they know it has electric folding mirrors or not.
Will the mirrors fold manually or will something inside break if they are folded manually?
This morning, I went to un-fold the mirrors to leave for work, and the passenger side mirror took 3 - 4 times of pushing the button to finally get that one to move to unfold. The drivers side worked each time.
Any ideas?
I would say yes, they can break if folded manually. I dont have them on my current truck but my last one had them. i folded them manually once and when i went to open them back up i heard a clicking sound like they were off track. It took a few tries for them to open up. Next time you go to get er cleaned up, just fold em before they have a chance to do it for you.
They won't break. The loose/sloppy movement is a built in safety breakaway. If you cycle the power mirrors after they're supposed to reset.
Can they get broken? Yeah I suppose if your a roid raging idiot when manually folding them in it could happen, but no they are built to be able to manually fold them in and aside from the over aggressive ass that would break a manual one no they will not break.
I don't like to power unfold after they have been manually folded. Makes a heck of a racket.
Can they be broken? Yes, they can, by mindless, careless idiots who ignorantly waddle into them in garages and parking lots, then practice denial and deflection in the highest degree when called on their moronic actions. Even then, it's still illegal to beat the hell out of the senseless, failed biological experiment.
    needafix
    needafix
  • Who's Online   3 Members, 0 Anonymous, 624 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
