N-Fab steps, #C1173QC
You may have seen my other topic that I just installed a set of these steps.... http://www.gm-trucks.com/forums/topic/152190-n-fab-steps-installed/?do=findComment&comment=1339186
Well In there I mentioned that I had another set of these that arrived with a paint blemish and the manufacturer made good on them.
This model step fits :
2011-2012 Chevy / GMC , 1500/2500/3500 Ext Cab
I am looking to get $275 -Local sale only to Buffalo NY area. I am willing to drive to meet you within the western ny area. If you want these shipped , I can get a quote but it will be pricey because of the weight and size of the box.
Here's some pics:
The blemish..
Need these gone. I'm open to shipping these depending on your location. I will ship to the U.S. only. Still have original box, wrapping. I will wrap each bar well in bubble wrap. give me your location and i will get you a total quote. If i ship these hoping to keep it around $270 total. But this will depend on your location.
If your local and are interested in picking up or meeting, . $225 !
I live in VT, man that sucks you live so damn far away. I live about as far east in VT, almost in NH and you're just about in Canada... Im traveling to PA in a couple of weeks but I dont believe we will be going as far west or if they would fit in my womans rig... very interested though
Jerry, let me check and see when the son-in-law will be back up there, I might take them off your hands if you still have them. :jester:
Jim, I dont think they will fit a crew cab. I believe its just 11-13 ext cab.
I see that now I thought that they were for the crew to bad I really like the look of those. :jester:
  • 1 month later...
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
