Blackhawk7 Posted June 8, 2013 Posted June 8, 2013 So, I've recently swapped all 4 of my turn signal bulbs in my 09 1500 to LED's and the seller description was a bit deceptive in that it stated they shouldn't hyper-flash. Well, needless to say they do and other than the visual disgust I don't need people thinking I have electrical issues with my truck. I've been browsing online and stumbled upon these... Can someone please give me some insight on if these will work on my turn signal wires? I want to make sure the bulb socket is the same size as the one on the actual wiring assembly so it keeps a good seal and won't cause my headlight lens to fade in a couple months or whatever. http://store.ijdmtoy.com/3157-LED-Hy...s-p/aa1069.htm I am aware there are resistors that you quick connect with the wiring but I do not want to cut into my wires if I do not have to and am more than willing to pay the extra amount if these will work.
SnakeEyeSS Posted June 8, 2013 Posted June 8, 2013 Looks like they are just extension with built in resistors. Great idea....no soldering! You get them please let us know how it works. Im interested as well!
Blackhawk7 Posted June 8, 2013 Author Posted June 8, 2013 I thought at first they looked generic, but I figure I can fabricate something if the seal isn't perfect. I'll post results once I receive them and hook them up. Most likely be around mid week to friday.
Blackhawk7 Posted June 13, 2013 Author Posted June 13, 2013 Yeah... Stay away from them... Still hyperflash... * bashes head into nearest wall *
SnakeEyeSS Posted June 14, 2013 Posted June 14, 2013 Yeah... Stay away from them... Still hyperflash... * bashes head into nearest wall *That stinks*Hopes fade*
Sinkhole Posted July 23, 2013 Posted July 23, 2013 The only LED bulbs I have ever trusted come from SuperBrightsLEDs.com. They are bright, reliable, and just flat out work. http://www.superbrightleds.com/cat/led-vehicle-replacement-bulbs/
Blackhawk7 Posted July 23, 2013 Author Posted July 23, 2013 Sinkhole, Are you just trying to advertise your product? Lol Do they hyperflash still without load resistors? Someone please take the initiative and build a resistor into the base of the bulb, we don't want to cut!!!
Sinkhole Posted July 23, 2013 Posted July 23, 2013 Sinkhole, Are you just trying to advertise your product? Lol Do they hyperflash still without load resistors? Someone please take the initiative and build a resistor into the base of the bulb, we don't want to cut!!! I have no affiliation with them. I just recommend products I have used, that work. As a mobile electronic installer I see all sorts of products, of varying quality, on a daily basis, and will give you my honest opinion of products I have worked with or use in my own vehicles. I'm not 100% sure if they will hyper flash or not with the stock flasher. I had a bad flasher in my truck and replaced it with a "no load" flasher before I did any of the turn signals. There is no need for load resistors if you just change out the flasher. They are like $13.00.
