uh oh, no low beams!!!
So went and fired my truck up this morning and released the e brake and normally my lows start to heat up (HID) but only my turn signals came on. So I checked fuses and were good. Bypassed harness for HID's but nothing. Swapped low beam wire over to high beam. Didn't even turn those on. High beams and fogs work. So for right now I swapped my high beam harness to my low beams and have to turn on my highs when I want my lows haha.
Any ideas? I also replaced relay and nothing happened as well. This is kind of really important considering I drive to work at 430-5 in the AM
Relay, fuse, ballast, bulb, wiring. All those should be checked
Replaced switch and that did nothing. Already had one laying around so it's not like I wasted my money or anything. So I moved on to a couple other things...
Didn't realize I had an inline fuse for my harness for my HID's (so they warm up faster). Checked that and it fell apart! So I replaced it but it didn't do anything. So I just completely bypassed that harness and plugged the low beam directly into the HID. Boom! It fired right on up! So now I either have to check for a short in the harness and possibly rewire it, or just remove the harness altogether. My HID's are DDM tuning HID's so not the best quality, and so is the harness, so maybe something came loose up near the relay or like I stated before, there is a short somewhere.
What kind of HID's do yall have out there that are pretty quality built?
None on the truck ('07 900 series), as I found the lighting on that to be the best feature of it ... but we threw a set on our '86 Grand Marquis. A little different than the 9006 or H11's of the 800/900 trucks being an H4, but the components to activate and run them are the same (minus the high beam). As we expected, it was a literal night & day difference in light output over the sealed beams.
Don't know what the specific brand of the kit is, but I bought them here: http://www.coolbulbs.com/HIDKits_body.asp
The place claims that these are the exact same units used on the high end German cars. We only drive the Marquis in the summer, but these lights have been on there since November '12, and have worked flawlessly from the frigid single-digit to below-zero New England winter to the 90° summer days at 75% humidity we've had the past week.
Here's a couple pics of the components where you can see the manufacturer's logo:
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
