I suspect my 07 Silverado 2500HD may have a 4.10 or a 4.56 rear end
Reasons:
1. Both times I've checked the gas mileage, it's 10.3 and 10.9 mpg, in a mix of about 20% 50mph+ and 80% city. Usually with my other V8 trucks and vans I get around 14-15 mpg for this, my usual daily driving pattern.
2. Also, I believe there is supposed to be a tag somewhere on the rear end indicating it's a 3.73 ratio. It's missing on this truck.
3. The truck came with a 2½ by 2½ hitch receiver, which is for really heavy loads (around 16,000+ lbs I think). If the original owner was towing anything in this range, I would think that a rear end change to 4.10 or even 4.56 would have been on his short list of mods.
The RPO codes indicate the truck was built with a 3.73 rear end.
How can I tell for sure? Do I jack up the rear end, and count the number of drive shaft revolutions per wheel revolutions (or do I have that backwards?)
New body style i am assuming as the 6 liter engine 2500hd Gmt800s all had 410 gears. Tire size of course too. If you really think its been regeared jack it up and pull the rear cover off and look. Probably needs an oil change anyway.
A 6 speed truck with 373s and the oem 245 75 16s turns around 1800 rpm at 65 mph. If its significantly higher than he may have regeared. 410s don't make that much difference on the trucks mileage wise... like not 4 or 5 mpg. 4.56 would make for a really short first gear too lol.
Sent from my SGH-I747M using Tapatalk 2
You aren't providing much info. We are to assume you are talking about a 6.0L engine simply because of the gas mileage. However, unless I am VERY mistaken, no 07 NBS's had 6 speed transmissions besides the D-Max. Also, they didn't ALL come with 4.10 gears, most came with 3.73s. All in all, that much city driving and (assuming you only have 4 gears plus reverse), 10-11 mpg sounds about right. my 03 6.0L with 265/70-17s gets about 10-11 mpg average with a 4.10 rear end. Easiest way to tell, jack the truck up, chalk the tires, put a chalk line on the tires themselves (to see how many times it goes around), have someone spin the drive shaft one full revolution and watch how many times the tires go around. Or you can take the rear diff cover off (since who knows the last time the rear oil was changed and you can put fresh good stuff in it), take a wax pencil, draw a line on the ring, one on the tire as well, have someone spin the tire, you count the tire rotations per one ring gear rotation. Both are good ways to tell. Also while you're in there on the second method, you can inspect for any uneven wear or damage since the original owner had such a large hitch on it for towing.
Edit: at 60 mph with my set up, I am at about 1800 rpm as well.
GMT800 2500hds with 6 liters have 410s... check your owners manual if you don't believe me. There is no optional axle ratio and wasn't throughout the run. I am talking 2500hd here.... not a 2500 light duty, not a 1500hd... Now GMT900s changed that. And yes since its a GMT900 the op has it has a 6L90E.
New body style 07, tires are Michelin LT265/75R16's
60mph - 1750 rpm
70mph - 2000 rpm
Measured in 6th gear with the dash tach
Your truck has the 373s the truck says it came with. Indentical setup and rpm that my 09 2500hd did with 373's.
My 2500hd came with the large receiver and 3.73 gears.
Mike
My 09 had the 2.5" receiever too. I believe that all 2500 hd and up trucks got the bigger receiver on the gmt900s. In fact I will just say they did.
So I guess this truck is going to get even worse mileage than I thought? LOL
Oh well... so long as it tows my 10,000 fifth wheel I'm picking up from my Uncle tomorrow morning, I can live with that. Thanks for the opinions and info
I just don't think you will see man HD truck's rolling around with 3.23 gears so yeah, low gas mileage but awesome towing.
You have all the information that tells you what your truck came with on day 1 from the factory. The only way to know if the previous owner re-geared it is to get under there and see what you got. As for mileage and capacity... It will pull it and you will be getting even worse mileage. Have fun!
07 to 10 gasser Hds came standard with 3:73. 4:10 was available option. Same holds true for 11+ HD. I have owned three HD GM gasser since 05 and had to factory order all to get 4:10 axles.
You can run your VIN online (google) or ask any GM dealer to confirm which axle you have.
+1, your right on.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
