2014 Quicksilver Metallic Sierra
  • Replies 44
4X4Sierra5.3,
Congratulations on the purchase of your new 2014 Silverado! Please know that if you ever have any general questions or concerns GM Customer Care is here on the forum. We are only a private message away.
Safe travels,
Jennifer T.
GM Customer Care
Sweet looking truck.. It almost looks levelled already.. very nice. I have one on order now and have 8 weeks to go.. Cannot wait....
enjoy your awesome truck bro.....
- Alan
Great looking truck! The silver would have beeen my second choice, behind the white diamond. You done good!
I like them wheels, as you can tell by the pic below. ;-)
Yea I almost got white diamond but in the end I couldn't justify an extra $1,000 just for paint...
Sent from my SCH-I535 using Tapatalk 2
Back in Black - almost went with the Blue Granite though
Looks great. Blue granite is great too. :-)
The 22s are gorgeous. I was tempted but since my previous car had low profile tires, I had received some curb rash. I wanted enough rubber to clear the curbs......but the 22s look great.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
