Clarion powered subwoofer and SEO 12volt source?
hikerboy
Looking at ordering a Clarion SRV250 compact powered subwoofer to go underneath my rear seat in my 2005 Extended Cab Sierra.....I've got a Sony headunit with RCA outputs, plus upgraded Pioneer 3-ways in the front doors and coaxial 4x6 in the rears. Sounds great but needs a little more bass. Wondering if it would be OK to source the 12 volt fused power lead to the 15 amp "constant hot" (MBEC pin #4) in the SEO box under the dash instead of fishing the lead up to the positive side of the battery? The Clarion unit draws 7 amps, so I'm thinking it would be OK, but looking for advice. I've got my steering wheel control box sourced to a switched power pin in the SEO, using the info shown here....
http://www.gm-trucks.com/forums/topic/126474-gmt-800-retained-accessories-power-rap/
Seems like it would work fine? Thanks for the feedback.
Yeah, it should be OK. That amp in that system is pretty weak and doesn't really pull a lot of amperage. Those work better in sedans and SUVs. I try not to sell them to truck owners because of the lack of airspace in the cabin.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
