New Order - Factory LED Bed Lights
Hey Guys
I have a question in regards to the LED Bed lights. The lights are factory installed but I have a question on how they are integrated into the bedliner? The bedliner it looks like is installed at the dealer. Anyone have any experience on how this is handled? I guess what I really do not want to happen is I order the LED lights only to have the liner cover the lights. Comments?
Thanks
Mine bed lights weren't factory installed. When the truck came in there was a box that contained a wiring harness and the lights that had to be installed by the service dept before delivery.
As long as your dealer has the most updated bedliners in stock, they have the light provisions already built into it. We have yet to sell one and put a liner in one but I think the plastic is molded shorter or lower near where the lights go. All the current bedlinder part #'s have light provisions but there are two different options for bedliners, ones without upper tie down holes cut in them or ones with the holes pre cut.
The lights are dealer installed and if they come with the truck as a factory option its only $60. The light kit without installation is $135 so if a truck on the lot was ordered with them or you order a truck and want those lights, save yourself the $$$ and get them as a factory option.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
