Looking for a shoulder rig
Mossyoakglock
Now that it is getting cooler and ill be wearing a jacket more, I want to get a shoulder harness for my 23. Does anybody have any suggestions? There are no places around me that carry any so I can't try them on before buying.
Galco Miami Classic II is a good, comfortable set-up. We use these for work when in courtroom dress and they work great. A little on the expensive side but well worth it.
Sent from my iPhone4S
using Tapatalk
Why did you post a photo of Michelle Obama
Sent from my Samsung Galaxy S4 using Tapatalk 4
  • 4 weeks later...
Galco Miami Classic II is a good, comfortable set-up. We use these for work when in courtroom dress and they work great. A little on the expensive side but well worth it. Sent from my iPhone4S using Tapatalk
I'l second that, in fact it is the only shoulder rig I use when belt carry is not an option.
  • 3 months later...
I have 2 ted blocker holsters and a belt. One is a shoulder rig. Love them.
