2015 silverado Z71 ... little over 1500 miles on her now
2.5 rough country lift front and 2 inch block in rear ( complete RC kit )
275 70 18 BFG's KO2 on factory rims
LTZ projector replica , really nice replicas , Eagle eyes with 10 year warranty
20151215_162342-1600x900.jpgattachicon.gif20151215_162507-1600x900.jpgattachicon.gif20151215_162546-1600x900.jpg
Like this setup. Any pic from front or rear. Do u like the width?
Edited by black 08
Took a trip to Pops today along Rt66 had to post a few pictures of my truck there!
5aafdf7c6697facc65d7ed7af1941433.jpg39898ff9dcf0f851c733bec67a70e377.jpge51a7380528d99588490668297a19456.jpg883d9c43c7698fa0d57ce1c5d3b976d5.jpg
Sent from my Z987 using Tapatalk
Brrr that looks cold!
I like that color.
I like that color.
Thanks I fell in love with it at the lot. Was going to find a color that matches my bike.... Oh well they both look good IMO 4d8eb4ccebd37a77917a44fb35b96d39.jpg
I tried to add the video! Was compressed and only 14 seconds but still too big. Any other option besides YouTube?
That is the way I usually post videos...(Youtube)
Here's my 2015 Silverado LT1 4x4 5.3
So far it has a 2.5 level kit up front, 15% tint all the way around, OEM color match grille, HID headlights and fog lights, 3" cube leds mounted on brackets under hood hinge.
Coming soon
All terrian tires, black bow ties, blackbear tune, 30" light bar behind grille, color match headlight bezels.
2015 Silverado
12466183_10207821312708142_7439100275223
Here she is surviving the 20+ inches of snow we got today. Performed surprisingly well considering the conditions!
12507548_10207951458561707_8179857044352
I added the driver's side grab handle today, no thanks to GM directions.
Sent from my SM-N910V using Tapatalk
Looks great! Do you happen to have a part#?
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 556 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
