Sure. I located two High Country grilles on EBay from dealers near me. But before I pulled the trigger, I noticed a High Country take off grille in the For Sale section. A member in NY had it taken off and replaced it with a color matched grill when the truck was new. He shipped it to me using the replacement grille's box. Used Paypal for payment. After the HC grille arrived, Took me about 1 ½ hours. Hardest part was getting to the 4 bolts that are underneath the bumper (behind headlights). I followed these instructions and video...
http://www.gm-trucks.com/forums/topic/156014-2014-silverado-grille-removal-how-to/
Here's the one I bought. Got my color matched door handles and mirror caps from another For Sale listing on here.
http://www.gm-trucks.com/forums/topic/180599-for-sale-front-grill-2015-high-country/
Nice... Thanks for the links and Info..
Love that blue. I was on the fence between the blue and the Tungsten Metallic.
looks good, what size are your toyos ?
they are 305/50/20. so they are a little taller than the stock tire set up, but it only throws the speedo off by 1 MPH at 70 MPH. at 50 it is only off by .6. I also wanted an offset that sticks out of the fender a little bit and did not want to worry about rubbing.
It will be awhile before they wear out but next time I might replace with 295/55/20. I think they should clear without rubbing and at that point when the truck isnt brand new, I won't be as concerned with the speedo. I installed these with 500 miles on the truck.
very happy with the set up so far
12301735_10100974358744406_5930562015513
Edited by emeryz28
Your truck went to the gym? :):)
Well... I went to the gym... Truck went to the gym yesterday and got a new exhaust.
See...
Edited by tyrich88
Been looking at all the truck pictures for a while now. I finally got around to posting pics of my 2015 Silverado.
11219578_10153135541811176_4359566454124
I like chrome when its do like this, nice setup!!
  • Like 3
Oooh. I like it.
What width and offset are your wheels? Looks sharp.
Before and after snugtop. 2016 slt Z71
Sold my replicas earlier today, and back on stock. New shoes coming tomorrow [emoji41][emoji106]7c694995e8f181a0f507db7e35db444a.jpg502d32c7ea84fd484224c2b399e78f1e.jpg
thanks!
20x9 + 1
305/50/20
2014 High Country 6.2L, CAI Intake, Corsa Sport catback exhaust, Diablew custom tune, Rough Country 2.5" leveling kit w/ 1" rear blocks.
  • Like 5
looks good . to much crome for me . may be a BLACK bowtie ?
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
