Chuck... Been looking to replace my grille with the High Country... It Looks GREAT!!! Can you provide me with details on your grille swap..
Sure. I located two High Country grilles on EBay from dealers near me. But before I pulled the trigger, I noticed a High Country take off grille in the For Sale section. A member in NY had it taken off and replaced it with a color matched grill when the truck was new. He shipped it to me using the replacement grille's box. Used Paypal for payment. After the HC grille arrived, Took me about 1 ½ hours. Hardest part was getting to the 4 bolts that are underneath the bumper (behind headlights). I followed these instructions and video...
http://www.gm-trucks.com/forums/topic/156014-2014-silverado-grille-removal-how-to/
Here's the one I bought. Got my color matched door handles and mirror caps from another For Sale listing on here.
http://www.gm-trucks.com/forums/topic/180599-for-sale-front-grill-2015-high-country/
Edited by chuckl1218
Do you have a level of any kind?
The RC 2.5" leveling kit.
Been looking at all the truck pictures for a while now. I finally got around to posting pics of my 2015 Silverado.
11219578_10153135541811176_4359566454124
  • Like 6
nice looking truck. That color reminds me of my dads 76 corvette. I will always really like that color!!
Very nice like the setup and color
Ryan
Awesome!
Nice truck. I really like the custom sport. I tried to buy a 2500hd custom sport but wouldn't accept my offer.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
