c07462474c49277fd39dd63be8ae5868.jpgca140e823b974e5fa3c77602817f2087.jpg89a8db3e7c360e02be7162e2973725c6.jpg73d14f986dc0c7f566277ba303d069b2.jpg733f7ccb54aac5ded8be5d54699c2b77.jpg
-2015 w/ 5.3L
-Bose sound w/ kicker sub
-Pro comp stage 2 - 6" lift (coilovers)
-35"x12.5-20 pro comp M/T's
-20x10 Fuel Mavericks w/ -12 offset and 5" back spacing
-Borla exhaust
-Color matched emblems
-Black lettering
-Black billet grille
-Line-x Bedliner (just got done today!)
Edited by muddy
  • Like 6
Out at Big Bend Ranch State Park. It was a 25 mile off-road drive. I completed the air damn removal mod on the way out.
Sent from the future via a wifi time portal.
Wonder how the Cooper's will fair in all of this PA snow. The forecast started with 4"-8" then 6"-12" and we ended up with just over 30".
  • Like 6
Pb_Foot, what size are those ZEON's?
Fat fingered, and shot from the hip.
Got my leveling kit on, and some new 275-70-18 Grabber AT2s So I went out for a photo shoot.
Edited by beyondbasic
  • Like 3
Damn, that is nice! What size life and tire size? Also what brand?
Pro comp leveling in front 2.5 inch and nitto m/t 295 55 20
Sent from my SM-N920P using Tapatalk
275 55 20, I was planning to up size them but had a hard time figuring out how much larger to go without rubbing and I didn't want to replace wheels too.
Some new pics (finally a clear sky here)...color matched door handles & mirror caps; High Country grill; removed door badges...
Chuck... Been looking to replace my grille with the High Country... It Looks GREAT!!! Can you provide me with details on your grille swap..
Do you have a level of any kind?
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
