No Fuel on Start. 1993 Rally STX 5.7 (TBI) 82k mi
MikeSp
When I turn on the key, I have no fuel into the TBI. I have fuel pressure into the regulator. I disassembled the regulator and did get it started. went to get fuel and when I tried to start it again, have the same problem. I have 12vdc at the injector contacts. Would like to know what I should be reading through the ECU. Didn't find any defects in the regulator, should I rebuild it anyway?
Any help with this would be appreciated
MikeSp
You don't mention it, but, have you changed fuel filter yet? Anytime you get a fuel issue on a fuel injected engine, always verify the fuel filter first. If you don't recall when it was changed, take a look at the outside of filter, if it looks old, change it. You also do not mention the fuel pump. Does it make the normal noises?
Can you check for fuel at the throttle body? Injectors will only pulse while engine is cranking/running, and you should be able to hear them while cranking with either a stethoscope or long screwdriver with metal end touching injector, handle held tightly to your ear. You should be able to hear the injector pulsing while engine is being cranked over.
If injector is pulsing, but no fuel is coming out, check for fuel at the injector. If no fuel at injector, follow line back to regulator and check for fuel at all three connections. A regulator that is stuck open(as in dumping fuel back to tank, try to block the return line to tank and see if you now get fuel to injector.
Fuel pressure/supply issues on EFI engines is about the easiest area to diagnose. To put it simply, check for presence of fuel, then quantity of fuel, then distribution of fuel.
I have changed the filter. When I do get it started, The injectors give an initial burst of fuel into the TBI when the key is turned on. no start if I don't get fuel when the key is turned on. The regulator is part of the fuel injector assy. I crack the pressure line and get fuel when I turn on the key. just don't get fuel into the manifold most of the. I'm suspecting the Engine Control Module, but Trying to find out what my meter reading should be from the injector plug through the ECM.
One thing with the tbi's before you blame the ecm is that the modules on the distributors crock and if the ecm doesn't get its timing signal from the distributor you won't get firing injectors.
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
