Sirius XM Pricing?
Thanks for all the feedback. How do you guys keep them from getting a CC number? Are you insisting on being mailed a bill and then paying by check?
They will bill you if you insist or just use a temporary CC number you can generate at your CC's site. Mine are only good for 1 month.
yeah I miss WSIX......the highway is SO Repetitive, Outlaw country is hit or miss and the "Burfurd" crap is embarassing when someone else is with me.... Sorry I'm not a dumb redneck and find that funny, Prime country is cool when you're in that mood as well as willie's Roadhouse BUT WSIX was a good mix of it all IMO
If they ever do get a credit card # from you they are almost impossible to cancel. Even if you go through the 30+ minute retention mess and are told they will turn it off, it doesn't happen. A few years back it took me four calls before they FINALLY flipped off the switch.. Now I have a bill sent and pay with a money order. I don't want them even having my routing & account numbers from a personal check. Their customer service has to be the worst of any company I've ever dealt with. Also when you get the auto renewal bill you can easily call and they throw the offers your way because they don't have any way of getting any more money from you unless you consent. Give them as little personal info as possible!
Amen!
I would much rather listen to the hum of my tires than ever listen to or deal with that sorry a$$ company again.
I've learned that pretty much all the info on this forum and others is correct. When I got my used truck I had to call and request service. Problem with that is they know you want it, so less apt to drop price because you are probably willing to pay more than someone who is just coming off a free trial. I managed $100/12mo. (introductory price) to start. When renewal came in at $180 I was like HECK NO and told XM if it's anything more than $100 I'm cancelling. So I was given a brief run-around and then told that since I am a "long-term valued customer" (yeah, 1 year LOL) I could keep my $100 rate. That was fine with me. Power to those people who go for even less than that.
+1
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
