The Baja Designs SII lights came today. One of the bennies of living less than 100 miles from the maker.
This little light is really tiny. But incredibly bright. 2160 lumens. I fired one up with some jury rigging. Amazingly bright for such a little package. These are the "wide cornering" lights with the Fresnel lens with a wide pattern like a true fog light should have.
Edited by spurshot
No switch. I will put my relay on the fog light fuse with a fuse wire tap.
So the led comes on with the fogs? Can you turn it on seperate?
Neat way to do the installation. No wiring thru the firewall and no switches in the dash to install.
That's it ;) Anyway, LED comes with the fog, I want more lumens when I will go on the offroad.
The lights available today are incredible. I remember tooling around the California desert in a 67 VW with a 6volt system and two lights that you could hardly see past the bumper with.
Later we discovered K C Hilites. This little company was taking light airplane 12v sealed beam landing light bulbs and making housings for them to mount on off-road vehicles. 4 100 watt KC Hilites would ignite the night, but your alternator was working overtime and they died early. Wiring and switches carried full current. Wires were big gauge.
So this is one old guy that is amazed when a LED assembly with a few 1" reflectors drawing 1/4 of the current, puts out the same light as a 7" landing light.
Any pictures up close of the led bar mounted behind the grille (Silverado), I want to see the where the mounts actually bolt to the truck?
I plan on putting a 40" Double Row behind my grille but want to make sure I know exactly were to mount it before starting the project.
Anybody receive their $60 lightbar from Beijing yet?
No I haven't. I was told anywhere from 7-3 all the way to 8-1 I should have it
Do you like the 6000K do you find them to blue. im trying to decide 5 or 6000
5000k is better, I think! But it's my old kit on my 2010 Silverado.
Looks like we may have got taken. Bunch of negative feedback claiming scam on his feedback now. When I bought, he didn't have hardly anything negative. Now, he has a bunch of unhappy people it seems.
I use this switch on my current truck, using the high beam as the trigger, and will be using it on my new Denali once it comes in. Keeps everything under the hood.
http://www.autoswitch.com/as7.php
Mdmischief, where did you tap in to the high beam trigger wire? This looks like an amazingly clean way of turning the lights on. Thanks,
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
