That's also where I put my switch the rubber holds the switch tight and do drilling
Well I fed the wring through the hole in the grommet a few times and couldn't see anything coming through to the cab. Definitely fed enough wiring for it to make it into the cab, so not sure where it is going. Any tips advice or pics as to where the wiring should come through? I couldn't get it done
I bet it balled up above the BCM. Try a coat hanger wire with some bright tape or paint on the end. I like to use a cheap motorcycle exhaust spring tool.
Just finished my install this weekend of our 24w flush mount pods. Used the Rigid mount plate and drilled a few holes for the flush mount. I like the look better using the flush mount. The Rigid D2 looks a little unfinished as you can see gaps around it between the light and plate. And the flush mounts match the shape of the headlights a bit. If anyone needs these we carry them for $40 each.
www.infiniteoffroad.com
Edited by allterrain14
What lm are the pods?
Output pics?
Don't have any at night but they are 3-4 times brighter than the factory fogs.
Post up some night shots when you get them.
Flood but spot can be ordered.
Is there any adjustment to it since it is a flush mount or no?
I have the original N-Fab light bar which you are correct mounts to the inside frame rails where the tow hooks are located. I can't imagine they would have redesigned the size of the bar just to add the multi mount rails, I assume they just welded their new rails where I have four tabs. Largest led bar I could fit was a 40" Rigid Industries which extends past the N-Fab bar slightly. I used the Rigid Industries 40" cradle mount and utilized the outside two mounting tabs on the N-Fab light bar, the center two were cut flush to the cradle mount since they will not be used. I really like my factory bumpers and planned from the beginning to find a way to mount the largest Rigid light on the front and a pair of Rigid Duallys on the rear, so N-Fab had the perfect solutions. I matched the front with the N-Fab Rear Runner.
attachicon.gifgmtrucks side profile.jpgattachicon.gifgmtrucks rear.jpgattachicon.gifgmtrucks rear runner.jpg
What grill do you have on your truck? Looks really nice!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
