Nice work. Another clearer shot of that grille please.
I'll try and get one tomorrow. It's snowing here and truck is dirty so I normally don't post pics of it dirty! Ha. If not I'll get one soon when it is clean. Maybe this one will work for now. This was before I did black tow hooks and the center bumper piece and then the rigids.
Sent from my iPhone
Thinking of going along those lines for my front grille. I think I want to stick with the DENALI chrome look, but nix the GMC emblem so it's cleaner. Your ride looks very tied together with that rigid fogs that couple with your light bar [emoji106]
Sent from my iPhone
Nice work. What size and brand is that? How are the results? Can you throw up a picture just alittle further back from the front of the truck please?
Sent from my iPhone
Sent from my iPhone
Thanks. Its a 30" curved from Totron. This thing is freaking bright! I'm very happy with the purchase.
54dcf734-8be6-4346-92e0-3df7deaae766_zps
I did this about a month back and found that it is actually pretty easy. I do have a few reccommendations though.... Buy a wireless remote/harness. Then you don't have to bother running wires through into your cab or mounting a switch. Also, you can program your remote to your garage door opener for a cost of around $50 CAD. It was a no brainer to me.
As for mounting the light, I just drilled holes in the cross braces that are behind the grill and mounted to that. The light I bought was a curved 33", and it just happened to line up perfectly to the spot in my grill.
Taking off the grill isn't actually that hard. I just watched a youtube video and had it off in less than 20 minutes. 4 bolts on top, 2 on either side by the wheel well, then 4 underneath (2 of those are a bitch to get at). I've had it off twice now, so its getting easier.
Hope this helps.
Took your advice and I think it is going to be way better. Started doing it this weekend but ran out of daylight before I got the grill off. The 7mm bolts on the side are super tight and I can't get a wrench or a socket up in there.
Hope this helps.
Paul,
would you be able to post a brand or link to the setup that would let me use my home link buttons as a driving light control?
Paul,
Most wireless controllers will let you. You'll just have to hold button on the wireless controller and on the home link. I have a lot from Ebay that worked just fine and a buddy of mine has 2 harnesses that are both hooked to different home link buttons
Has anyone used the Putco universal mount behind the grill?
Here is a link to it: http://www.realtruck.com/putco-universal-led-light-bar-mounts/R184129P2014Y856MA.html
Kind of expensive for behind the grill in my opinion. I used a 3 foot 1x1 aluminum tubing painted black for about 12 bucks and just bolted it to the arms holding the radiator. Actually mounting the light bar was the easiest part to me, it was getting the grill off and on that took some time.
New to the forum guy. love all the pictures and write up yall do. Once I get a pic I'll show yall what I've done with my 07 silverado ltz
Edited by travis.seeley
Has anyone found a pic or have a Tow hook light bar mount? May have already been one on here, but I don't recall seeing one. I've seen a ton for Dodges, but none for the new chevy. I don't like the behind the grill look personally, and don't want to drill into my bumper or buy a $1,000 grill and think the tow hook look is clean.
Just FYI, it'll interfere with the front license plate.
Here's how I did mine:
Edited by txchevy4ever
    btm
    btm
  • Who's Online   6 Members, 1 Anonymous, 1,531 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
