LOL maybe still high compared to yours but it is a HUGE difference to me. There was a 2in leveling kit on the front.
It looks good. But wait a few months. You'll want more
u can use some 4" drop control arms from a 08-13 silverado just an idea if your in a budget
Sent from my SM-G935T using Tapatalk
That depends on the arms is has though. Because 16.5 they switched to the avv arm. And the control arms didn't even fit in my truck right. So I had to get spindle and strut
He has the stamped steel arms. I have pictures. He could even just get the 2" lower arm for avv arms but after my djm experience. I say just grab the lowering strut
If you're having alignment problems its easier and cheaper to press in offset control arm bushings. You'll put the offset side towards the frame of the truck and it'll push the upper arm out to give you more positive camber. It got mine from -2.5* to about -0.8* on each side.
Just food for thought. I paid 90 bucks for a set of bushings and pressed them in.
So I've been reading through this topic and its a little confusing. I have a 17' CCSB 4x4 and I would like to do a 3/5 drop. I dont want to have to install a c-notch and I have stamped UCA's. What would be the best way to go about this without making it completely ride like crap. There are so many options but what is going to give me the best ride and not cause me driveline or suspension problems in the future from parts wearing out prematurely?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
