Seal teem what size tires/lift and is there any rubbing.
They are 20x10 Moto Metal wheels with 35" Mickey Thompson's. Has. 7" McGaughy lift. I had to cut 1" exactly on the front lower plastic spoiler. After that, no rubbing at all.
Thought I'd throw another one into the mix since I've recently joined the SIM Club. Here's my Silverado 5.3L LT. Had it less than two weeks. I LOVE the paint scheme ... I think the SIM looks great with the color matched grill surround and black bits from the rally option. (I axed the stripes)
BUT ... has anyone else noticed a blotchy appearance in certain lighting conditions? I first noticed almost a tiger stripe effect along the top of the bed in my garage. And then I started looking real hard in the sun ... the hood almost looks faded the blotchyness is so bad! It's on the roof as well.
I'm really not sure what to do. I took it by the dealer and the service mgr said it looks fine to him. Anyone else notice this?
Edited by Philshock
Here's another shot of the hood. Note that the truck is freshly washed and waxed and the hood is reflecting a clear blue sky.
From what I've gleaned from the net, this effect is somewhat inherent in metallic paint in general ... with some cases worse than others. I know I'm a picky sob but this looks like crap, IMO. Am I expecting too much?
Edited by Philshock
Sent from my SCH-I605 using Tapatalk
Did you paint the tailgate handle or buy one? I want to do the same to mine.
  • 4 weeks later...
  • 1 month later...
    Frank V
    Frank V
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
