2005 Silverado 5.3 1500 4WD Drivetrain Noise
woods95662
My truck has slowly developed a howing/growling noise in the drive train that is accompanied by a slight vibration. You can feel it in the gas pedal & floor board. It's tied to the speed of the vehicle not the gear the transmission is in. It's very noticable at around 60-70 MPH or above when you are giving the truck with just enough throttle to coast on a level surface. Basically feathering it. It becomes more pronounced when you are going downhill and feathering the throttle just enough so you aren't slowing down or gaining speed. You also can hear it for a split second when you let off the gas and the slack in the drivetrain changes to decelerating and then it goes away once the slack is taken up. The hubs and brakes are new changing them did not affect the sound in any way. I didn't expect the hubs to be the issue it didn't sound or feel like that was the problem.
I'm looking for some direction on where to start. It feels and sounds like it is coming from the front end or front half of the truck.
Just going by what you are describing, I'd start looking at the universal joints in the front driveshaft. I have a lifted sub and when the u-joints are going out in it I get the same as you describe.
I think I have the same problem as you although it has only shown up recently since it got cold.
My u-joints are new as of about 2 years ago but to me it sounded like a heat shield rattling. I had a similar experience on another vehicle that the heat shield would rattle and make a funny noise only on acceleration and only while making a right turn. Weirdest thing ever.
I have not however had a chance to look at it yet so I'm just guessing. Let me know if you find anything out.
in 2WD. t's definitely not a heat shield it's more of a groan or growling sound tied to the driveline speed. I'm going to check the U Joints that was next on my list I'm just not confident it's the issue.
  • 8 months later...
Update: Well whatever it is it's getting worse. I'm starting to think it's coming from the front end which doesn't make a ton of sense being that it's in 2WD. Hubs were replaced and had no effect. Transfer case is new. Transmission is in good shape I've never had any issues. I'm stumped. I'm also getting a slight whining noise as the truck picks up speed. I'm starting to wonder if a differential is going out on me.
    • Whoever greenlighted the work truck matte black front bumpers on every trim but the AT4X should be fired!  I was hoping that was an AI mistake, but just realized they were on every model of the 2027 Silverado too.     Some parts of the interior do look premium, but the Denali Ultimate dashboard looks like an afterthought.  At least they appear to have lost the microfiber the high end Silverado models showed, but the '27 High Country dash looks better than the Denali.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
