Rear window regulator
I had my Rear window regulator changed this morning as my vin was part of the TSB. Wasn't much to it, took mechanic longer to remove the rear seat then it did to replace the regulator. Took about 40 min total.
What was the service bulletin number? I was told by gm customer service that mine is included in this recall. The number I have is N130318. Any info appreciated so I know what I am getting in to.
So this fixed your rear window rattle?
Never had the rear window rattle. Actually I never had any issues with the rear window.
Not sure what it was, heard about it here on one of the threads in the forum. Invoice is out in the truck. If someone doesn't chime in, I'll look on my way home from work.
Not sure what it was, heard about it here on one of the threads in the forum. Invoice is out in the truck, If someone doesn't chime in. I'll look on my way home from work.
Thanks
It looks like the cut the backside of you cab wall up, is this the case, or is there a legit access panel to the regulator motor?
I was with the mechanic as he did the swap, there is an access panel that he is holding down why I shoot the picture.
Mike
    Kirk Belch
    Kirk Belch
  • Who's Online   5 Members, 0 Anonymous, 1,328 Guests (See full list)
