Finally Bought my 2014 Silverado LTZ Z71...my experience
Sounds like the guys attitude was way out of line & NOT acceptable.
Am sorry this happened or worked out the way it did. BUT to play devils advocate (hypothetically) here. If I show up to your house to buy a truck you are selling & am going to give you a partial check & a promise my bank will send you the rest later, would you let me leave with the vehicle? Remember, am not from across the street & live several states away. I would not if I was the seller.
Guess the thing to remember with making a deal online is if traveling a long distance to ask what payment type the dealer needs to release the vehicle. When I went down there I was prepped to walk out on the deal if the Finance guy was out of line. Am only 100 miles away though & had a car to leave in. Had no issue what so ever & did not get the sales pitch for all the extra crap dealerships in general want to sell you. The only difference was that I had a cashiers check in hand.
  • Replies 32
Well, as I mentioned...payment was supposedly worked out before hand...and supposedly was acceptable as to how it would be processed. The salesman stated it would be fine if I just wrote a personal check as one of the acceptable payment methods. So, that in itself should have been fine. However, the Finance guy made an assumption that I did not have that money in the bank. Regardless, it's not for him to say whether I did or did not! And as to compare me selling a truck privately to an individual out of my house as opposed to a big dealership selling a vehicle...is kinda like comparing apples and oranges...both are round...but different scenarios. I'm sure they are well insured against theft...not to mention they are multi-million dollar operation. And not to mention the verification process that we went through on the cashiers check. Anyway, it's all good now!
I meant no offense what so ever. Just had the exact opposite experience there with those guys. Kept waiting for something to go wrong & it all went great. WITH exception to a deer running into the truck on the drive home about 3 miles south of the house. :banghead:
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
