Posi Rear diff swap
I have a 95 z71 with a 350 and could use some help picking a posi rear diff cause I don't have tow/haul mode and want something that both tires will spin when I want to go slide around a corner or have a bit of fun (stoplight take off's included)
Tow/haul has the locker to hook up posi and help with hauling, towing ect. but in general it's a pain when I start to slide (whether on purpose or by accident) it would be a bit nice to not have the stupid bouncing feeling when the a$$ end slides out
Tow/Haul has nothing to do with whether or not the truck is equipped with a locker in the rear (different than limited slip, aka posi, by the way). Tow/Haul wasn't even available until the 1999 model year with the introduction of the GMT-800.
Also, keep in mind if you're wanting to minimize sliding while cornering, the addition of a locker can cause the pickup to slide easier once traction is lost as the rear now has the ability to fish tail instead of powering one tire while the other attempts to keep the pickup tracking straight. Just some food for thought.
Well I can tell ya a posi rear will disengage if the rear tire speed is above 25mpg. Any posi wont last long on the treatment you want to give it.
Again tow/haul has nothing to do with the rear, it changes shift patterns in the trans.
And that's why I suggested the Yukon locker to him. It unlocks at low speed turns so you aren't bouncing the rear in wet cornering situations.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
