CHROME CLAD OR CHROME on 2014 Silverado
sams819
Does anyone know for sure if the 20 inch wheels on the 2014 silverado from factory are chrome clad or chrome wheels?
pretty sure they are chrome.
I have not seen any chrome wheels on the Silverado, only the GMC trucks. The 20 wheels on the ones I have seen are polished aluminum, not chrome. Can you post a picture of what wheel you are talking about?
these ones
Can't see a thing
these ones
Ok I dunno I have not seen these yet. The only ones I seen were on the LTZ but were a different wheel.
these ones
Mine are like these too. They are chrome, not chrome-clad.
How about the ones on the 2014 Sierra SLT? chrome or no? I ask because that'll depend on the cleaning chemicals I use this summer...
Sent from my DROID RAZR HD using Tapatalk
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 999 Guests (See full list)
