I had a repair shop order the parts so I do not have the part numbers. The owner told me there were SEVERAL pieces that he had to order and will put together once they arrive. My truck is still on dealer lot due to state of IL delay in registration/plate protocols (company-leased truck).
I will keep everyone informed as soon as the install begins..
Ok guys finnaly got some good news in today I was able to get a hold of one of two consoles available in the nation it will be in my hands on the 17th can't wait to put it in also gonna road the truck with dynamat and install am my jl audio components along with a jl audio 8w7 which they say is impossible but I'll make it possible I'll take pics of the process and post them as soon as I stsrt
The GMT-800 series has the LS series motors in the aspect that the motors are from that engine series design, but the only truck that I know of that have had the actual LS2 motor was the trailblazer SS and the SSR. Other than that I don't think any of the GMT-800 or GMT-900 trucks ever had a LS1 or LS2 in them.
Nice any part numbers on the box??
Sent from my HTC One using Tapatalk
What are you asking?
I'm asking what the part numbers are for the console. My dealer can't find them
Sorry, no idea. I was just commenting about the LS series engines.
What else was added to finish it off? Can you post a price for each item you used to piece it together? Also interested if the plugs are pnp for the usb, outlet etc.
This plus part numbers would be awesome!!!
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 279 Guests (See full list)
