23466980 shows online it will not fit my 2016 , I guess that is not correct? I tried the 23466999 and found nothing?
The 6980 was from the 2015 model so it comes with an SD card slot inside as well, but it does fit. I ended up switching my USB/aux port from inside the original fold down console with the USB/aux/SD port that came with the 6980 console, and now my apple carplay works as well.
Great .not to worried about the outlets will worry about that later Just want make sure the thing will work and look stock!
One more , looking for black , silver or grey upper trim and seems some are discontinued , they do have this but is it silver or grey or tan or what?
  • Manufacturer:GM
  • Part Number:23467112
  • Part:Upper Trim Panel
  • Part Notes:Upper trim, with 110 volt outlet, reverse tartan.
  • Never mind found the silver one
Edited by breid1983
I noticed someone of you said that you need M6 bolts (M6 X 1 I believe), but what type of bolt head would you recommend?
Amp rack with 1 jl audio 600/1 waiting on the 400/4 to fill in the other slot
Rhino lined my ported box
Painted faceplate will paint some other panels soon
what color did you use to paint interface?
UPDATE:
Parts ordered today , finally found a code for free shipping, before was looking at $190 for shipping, total cost was $625 , thanks for the thread and help, good stuff right there!
Ok someone posted a junk yard search link. I looked up a console and found LKQ/Keystone in Wayne MI close to my work. Got a near complete black console with the z71 reverse hounds tooth trim for $137 otd mint. Missing the front dash bracket and cupholder piece. Can you get the cupholder seperate? They said they would find them for me cheap. Smells like a fruity airfreshner but ill clean it.
Just the cupholder or the whole plate assembly?
Great i took a few hours today and put my junkyard console in. Your all right once you get both harnesses out, look at them you can see where to splice them together. I soldered and shrink tubed all my connections. Only thing is i am waiting on a usb cable #19303284 from the glove box usb to console USBs. Was pretty strait foward. Looks sooooooo much better the way it should have. Thanks go Slatemetal15 for the Pm help
Edited by afireinside7444
Do IT !!!!!!!!!!
I just got tracking # , it will be here Monday !
Where did you order yours from I'm looking and when I put the numbers it said part discontinued
Sent from my SM-G935V using Tapatalk
http://www.gmpartsdirect.co/
I have a 2016 It fit perfect, I ordered the wrong bracket, bottom instead of front, but with no front bracket it is solid and absolutely no shake. They wanted $190 or so for shipping, but I googled it and found code for free shipping. I also ordered a cable that was wrong, so I wasted about $30 there. I have not finished the wiring but have a 110 and a lighter socket working, all I need is one really for charging phone.
Console Assembly
Part # 23466980
Item Side Trim
Part # 22817347
Item Side Trim
Part # 23467516
Item Upper Trim Panel
Part # 23467113
Wrong Parts.
Item Cable
Part # 19303284
Item Mount Bracket
Part # 23467730
Edited by breid1983
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,164 Guests (See full list)
