So what's the best way to sea foam a 5.3 I used to pull the booster line off my 4.7 ram and suck it in there just wondering if there is a better way thanks
They have a u shape tube for the sea foam so you can stick it in thru the throttle body intake tube.
is there a how to on this some were?
Sent from my SCH-I535 using Tapatalk
I think there is a short vid on youtube. But basically you loosen up the intake, slip the seafoam tube(its tiny like a WD-40 tube, only curved) pointed toward the throttle body. Start the engine, hold the spray down for the designated time(while the engine is running), turn off the motor, take the tube out, re-tighten the intake tube, etc . I forgot the rest of the instructions, but my truck smoked a little, and then ran clean. Overall pretty easy. I hope this helps.
Oh must be different then the season I have used in thr past as it was not under pressure
