My new 2014 silverado sounds like it has a loud turbo whine under light acceleration. Started at about 1200 miles. It is loud enough to turn heads. Took it to the only dealer in 100 miles and they drilled a hole in my muffler to enlarge the weep hole. Now my truck has a nasty looking hole, a whistle and now a swooshing sound. They ruined my exhaust. I use to like this truck!! They say they called GM and there is no fix. I don't know what to do. This is not normal. It also has a ticking sort or sound at idle they try to blame the injectors. You can hear it 100 feet away! GM wonders why they are not selling. It's not the trucks. It's the service from the dealers when you have an issue
  • Replies 31
Top Posters In This Topic
Well I know mine had that issue while at the dealer for a Fuel Pump Recall and was fixed after the new fuel pump and module.
I don't think it's the fuel pump. The ticking is a dull ticking more toward the engine. The turbo sound goes along with the rpm and light throttle. I thought it was a vacuum leak. They say its the weep hole in the muffler. I am going to plug it completely and see if the whine goes away.
Best bet is to drive it hard and put some miles on it. See if things get better as things break in and settle.
Painter 1992,
I have a 2014 silverado 5.3 ltz and it makes the same stupid ticking sound you can hear 100 feet away.
There is a weep hole back by the resonator. I initially did the muffler delete, and it sounded terrible, the weep hole noise was certainly more pronounced. Just put your finger over it, while the truck is running. Not sure I'd permanently block it as condensation will certainly build up in that area.
Ticking noise is nothing more than the direct injection.
The weep hole sounds is like air sucking in if it were a pump right...mine does it while idling every couple seconds.
It's actually pushing air out and has a slight whistle to it. It may be more audible once condensation is present, hence the every couple of seconds. IDK just guessing here.
Mike
Mike
That's it...you described it perfect. Is it just me or do these new motors sound terrible when just sitting there and idling???
Exactly the same as mine. I even went to the dealer and started 2 new trucks and they were the same as mine. Ticking and s completely normal to DI engines. I would like to see though if someone figures out the whine though.
Well, I removed everything up to the last catalytic converter ( to include the "whistler' and the spring flap BS) replaced with a 18" magnaflow muffler. No more whistle sound and now my truck sounds like a v8.
I originally thought it was a bad torque converter/front main on the tranny bearing or something. That's what my father said too... YOU ARE NOT ALONE. Lol
Yeah, mine ticks too. The only thing I would change about the truck. It's pretty loud in V4.
Well there is a Company who can turn it off and it's not traceable if it bothers you that much. Too expensive for me, for what you get. I'd rather get a tune and have the ability to shut the AFM off.
The "ticking" you describe at idle is the direct injection system. They are louder than standard fuel injected motors. Perfectly normal characteristic of direct injection.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
