53718535859587416bdbdc49e596a8a6.jpg some more dipping. Went from chrome grill to black and white bow tie. As soon as I get some cash ima take the bottom black piece to my guy to get it color matched.
Has that bottom piece always been black? I thought it was white at one point.
I would just dip it until you can get it color matched
For the 2wt is black, only LT+ have color match. I thought about it but haven't had time to take it off and do it.
More minor additions- added Husky Weatherbeaters. They're not as thick as the pictures and videos make them appear to be... I'm going to write to Husky to ensure I got an authentic product. (Got them on Amazon)
Finally let another man get under her and touch her... 2.5" RC leveling kit. Exactly what I wanted. Gives the illusion of a near perfect level.
Got a chip in the windshield repaired, regular maintenance and realignment. Not my most exciting day with the truck. But this weekend it'll get some real work done!
Front windows tinted and Paint/Interior/undercoating applied today.
I'm liking the color matched XM Radio antenna. How did you pull it off to paint it? I have considered trying to plastidip mine to color match the rest of the truck.
This guys white hd is something else , what an awesome looking truck
The High Country comes like that standard along with the spray in bed liner.
Sent from the future using a Fax
Thank you. Very happy how it's turned out. A few more mods and the list is "complete".. For now [emoji87]
With modding there is no "complete" it's more like "till next time"
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
