Antilock brake system activating when turning
When I turn and press the brake and sometimes when I'm going straight the antilock break system activates where it pushes the brake pedal up and vibrates as if the wheels are sliding on ice or mud. What causes this problem ? Has anyone else had this problem?
First thing is scan it for ABS codes. It may help narrow things down. It can be several things
no lights no alarms just physical reactions... could air in the brake lines cause this? ive recently had them replaced so that could be a possibility.
You don't have to get "lights" to set codes. If there are codes it may help narrow down the problem
Check with a scanner capable of reading ABS codes.
It could be bad wheel speed sensors or wheel bearings or......
No ,air does not cause this ,
Hey Rick,
I apologize for any concern this has caused. Have you reached out to your dealership regarding this? I would be happy to assist in setting that up. If you would like my assistance with this matter feel free to reach out via PM with your full name, contact information, VIN, current mileage, and preferred dealership.
Sincerely,
Jonathan A.
GM Customer Care
    250.3k
    jkptuned
    jkptuned
  • Who's Online   6 Members, 0 Anonymous, 932 Guests (See full list)
