Putting my 2014 Denali in Storage for 5 months..
Just a thought on the water in fuel thing, and I could be wrong. Her in Florida it is an issue on a boat due to humidity and the fact that boat tanks are open vented to the atmosphere (at least up until this year- new Govt. rules) That being said, I have never seen this on a vehicle because the tank is a closed vented system. Yes its vented but through filters like charcoal canisters. Just my opinion but I don't think water will accumulate.
I would Pull the battery, put stabil in at about 1/4 tank and run it until the fuel light came on the jackstands are a good idea too.... no wrong way most people would just park it and go so you'll be ahead of them... you gotta think some of the 500 car mega dealers the wierd optioned vehicles sit that long without being driven... when i was working at the Dodge dealer, we were small but we had a Ram 1500 quad Big Horn with a stick shift. that truck never moved from April until November. not once. We jumped it to get it going for a guy to drive and he's still driving it trouble free last I saw....
I've stored a vette and a boat for over 10 years. Marine grade stabile is what u want, designed to suck moisture out. Designed for e85 for boats. Moisture and outboard motors bad :-(
As far as battery have done some redneck testing on this. Have 6 on boat. What I think works best make sure they r fully charged and then unhook them both negative and positive cable. IMHO
I leave my truck for 4-6 months every summer (past 5 years) when I travel to AK for work. I always top the tank, add stabilizer and disconnect the battery. Truck fires up fine when I get back. Mine even sits at the airport on the ramp side.
Luckily now I am married and have a house with garage, so wife will keep the new (14 Sierra) truck driving while I'm gone.
Pull the battery or battery tender for sure. Even when turned off these new vehicles have a pretty big parasitic draw. As far as the fuel goes I have never been a big fan of fuel stabilizer my motor home sits from October till April and I don't do anything special. I do have it plugged in on a timer so the inverter keeps the batteries up.
Why pull the battery completely? I've done a year sitting outside and six months with just pulling off the negatives
Sent from my SAMSUNG-SGH-I537 using Tapatalk
My Tacona sat for 6 months with no prep while I was in Afghanistan. Started right up when I got home. Since your truck is so new, the battery should have no issue. I personally wouldn't want to pull the battery since reprogramming the radio is a PITA.
I would fill her up with non ethanol fuel if available, set truck on blocks to avoid flat spots on the tires and disconnect battery.
That will be done.
Any other precautions or things to do?
One thing that no one has mentioned is tires.
Make sure your tires are inflated to the recommended tire pressure. If a vehicle is left stationary for too long, the tires could develop flat spots as the weight of the vehicle presses down on the tires' footprints. This process occurs at a faster rate in colder temperatures and with vehicles equipped with performance tires or low-profile tires.
In some cases, simply having someone drive the car for awhile will bring the tires up to their normal operating temperature and get rid of any flat spots. In more severe cases, a flat spot becomes a permanent part of the tire and you will need to replace the tire.
If your car will be in storage for more than 30 days, consider taking the wheels off and placing the car on jack stands at all four corners. This step requires more work, but it can save you from needing a new set of tires. Without the weight of a vehicle resting upon them, your tires will be in much better shape when you return.
Fill the tires up, I would go close to thhe max pressuue. I do this in my camaro and it helps reduce flatspots
This is what I do to my car before storing my camaro in the garage
Fill the tank
Add stabilizer (Seafoam or Stabil)
Detail (Wash/Wax)
Connect to battery tender
Put on a car cover
In spring I pull the cover start it up and drive off:)
Its only 5 months, vehicles sit on dealer lots longer then that. Just park it lock it up and walk away. nothings going to happen to the fuel, yeah the battery might get low but if it does when you return just jump start it and drive off everything else is just way overkill.
I did a lot of research on this topic when my wife and I used the Silverado/travel trailer on an 8 month-8,000 mile towing trip and her near new (5,000 miles) Subaru Legacy needed to be stored. This is what I did-
1) Filled up fuel tank
2) Added 1 can of Seafoam and drove the car for 10 miles to get it through the fuel system
3)Filled tires 5psi over maximum
4)Put tires on carpet squares to prevent flat spotting
5)Pulled positive battery terminal off
6)Covered Car
Came back 8 months later and no ill effects car stared right up. So this is what WORKED for us.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
