Thought I would share what I did. I know it isnt what others are trying to achieve, however some people may be interested. I have a GMC with the LED daytime running lights. I wanted to be able to run just the LED strip with my fog lights. However on Canadian trucks it would turn on the automatic headlights. So to get rid of the automatic headlights, I removed the upper dash piece where you see the sensor. I unglugged the harness from the sensor bulb and added a resistor. This in turn disabled my automatic headlights allowing me to run the LED strip and fog lights whenever I want-Even at night if i disire.
I have no desire to disable the daytime running lights since I have the LED strip. Just wanted to get rid of the automatic headlights.
so you didnt want the auto night lights. so you must turn your low beam on maunaly when it gets dark? Edited by mattblackout
That is correct. That way I can control what I want on anytime day or night.
But you still can not control your LED strip (DRL) correct? They are always on?
Has anyone used a low pass filter to eliminate the pwm signal for DRL? I've been thinking about this for a while but haven't executed it yet. Should be faulty fairly simple with the right capacitor and resistor.
Edited by xtremespeed2102
When you say "in P" i assume you mean the light switch is on parking light (one click to the right). In this setting, while driving, both conditions are being met (power from parking lamps and power from oem low beam wire) so how would you drive with only parking lamp?
Lets step back and talk about the stock oem functionality. Because i think we have different situations. In USA silverados, when you shift into drive the low beams come on right. so here is my questions, can you be driving along (in daylight) and turn your low beams off with your light switch? and can you choose to run parking lights only while driving? because In Canada we dont have that option. We can not turn our low beams off unless we are in park. The light switch will not turn off low beams while in gear. so there is no way for us to run prkining lights only unless we do the pin swap.
On my truck in "P" my low beams are never on.
cool, so you can leave your switch on "P" and the low beams will not come on when you shift into drive?
Correct. I do it in drive-thru's all the time and pulling into my driveway or when near neighbor's houses at night.
I just completed the relay mod yesterday. It cost me all of $20 for a waterproof relay. I tapped into the parking light power and used it to signal the relay. The relay simply completes or opens the circuit between my factory low beam signal and the HID kit relays. Everything now works like stock Auto, Off, Parking, Parking & Headlights, the only difference is that the DRL's never come on.
The best part is without DRL's I've now been able to get rid of my capacitor thus simplifying the setup. And now I'm not cycling my expensive HID's everytime I start the truck and go from drive to park.
What wire was it for the parking lights?
It's a purplish pink wire with a stripe if I recall correctly. It's also very thin since it only carries current for the parking lamps-I think it was 20 awg. It's probably easier to identify it as the wire that connects to the fat yellow wire on the other side of the plug (the headlight plug). Anyways I cut the wire, joined it with an 18 awg wire to signal my relay using a butt splice and heat shrink.
I should add you only need 1 relay if you have an HID kit as most HID kits are single input for signal. Because I'm switching the signal wire going to the HID relays I'm not really load carrying so I'm not affecting voltage drop by using one relay/circuit.
    RichardRS
    RichardRS
  • Who's Online   0 Members, 0 Anonymous, 805 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
