Max tow discrepancy.
Boat show time of year and I got to looking at max ratings. The 2014 trailering guide says max for a 2014 1500, CC, short box with the 5.3 and 3.08 is 6,600lbs
http://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/MY14%20Trailering%20Guide_1113.13.pdf
My owners manual, section 9-? says 8,600 for the same thing.
Am I wrong???
is the higher numbe for a gooseneck style or fifth wheel style?
that could be the difference. with the 3.08's you should be around 7000 lbs...
Wow that is lower than the 4.8/4 speed/3.42 combo that came stock on my 2004
their towing is all in the gears. the 3.08's give you the least around 7000 the 3.42's bump it up a bit and the 3.73's are the max
Yeah that's right. The 3.42 is like 9600 and max tow package 3.73 is 11600? Sorry if I'm wrong on that one.. But the 3.08 is rated at 6600
Am I wrong???
I noticed that too. Im not a fan of the 3.08 combo for this reason, 30% less towing capability. What does it say on the door jamb? If true, that puts the Silverado in the mid sized truck capability realm.
I get that, but why does the manual say over 8k? The way it reads, it for the normal hitch an specifically says not a gooseneck. I mean, it's a ton difference.
has to be for the 3.42 axle.. does it specify the axle ratio in the manual?
3.42 is standard gear ratio for the truck it's prolly regarding that. 3.08 and max tow are options.
the 3.08 should be standard with the 5.3, the 3.42's should be an option and the 3.73's to my knowledge are only available with the max tow package
as for the descrepency in towing I dont know, but I know my 2010 5.3 ext cab with 3.08's is 7000 lbs, so a crew would be a bit less than that...
one reason I was either waiting for a new HD to come out or the max tow package "which is what I ordered"
I would go by what is says on the door jam. GM has been pretty bad about advertising discrepancies as of late. Of note, the heated seats saying remote start places the seat on hi warm capability or the 6.2 must use premium fuel...both issues have been contradicted depending where you look.
The 3.42 was supposed to be standard if equipped with the 20in wheel combo....come to find out GM slipped some 3.08s out there when there was distributor shortage....thats my biggest beef with GM. They advertise something as standard, yet it's really not.......like LEDs around the radio.....(beating a dead horse)
Excuse my ignorance, the door jamb says max two capacity?
Problem solved then.
It should. It should state max cargo and max towing capability.
