On 12/20/2018 at 3:25 AM, Ruckus Reid said:
Does anyone here have a 2018 or newer with the 8inch display? I want to turn the display off at night. Dimming it sometimes isnt enough. Problem is when i turn it off it doesnt stay off for more than 15 or 20 sec before it turns back on by itself. Just wondering if this is normal or if my display has an issue.
Press and hold the left (volume) knob and the infotainment will shut off. The screen will go black. Is that what you were asking? Or are you doing that and it comes on by itself?
On 6/21/2020 at 10:34 AM, MAGA Man said:
My 2018 Silverado does this :  As I drive it during daylight hours the display will periodically go dim to the point that I can't read the display very well. Then as I continue to drive along it will brighten up again.  The service person at the local dealership told me that the light sensor is being blocked by my dash cover. So I made the dash cover hole bigger so that there is no way it could block the light sensor. It wasn't blocking it before anyway. This mad no difference and the display still dims on its own.
Anyone have  any ideas??
Thanks
Mine does the same... very annoying.  Mostly when going through tunnels or shade (which is okay), but it takes for ever (if at all) for them to come back on.  I took it to the dealer for service and added this item... they said "use the dimmer dial to turn it up" .  ?  Not very helpful.
On 6/15/2020 at 3:54 PM, Ravenkeeper said:
There is a mod that can be done to make it dim even further, still controlled by the dimmer switch.  I had it flagged to "follow," but now it's not in my list.
I would SERIOUSLY like to have this mod!
Edited by Teutonics
I had it in my "threads that I'm following," don't where were it is.  Still digging.
On 6/15/2020 at 12:54 PM, Ravenkeeper said:
Daytime: should be full bright.
Nighttime: should dim down, depending on where your dimmer switch is set.
FOUND IT!!!!!!!  HOLY YIKES!!!
