'Interior Driver Assist Handle'
tenx82
44 minutes ago, Cupton said:
I couldn’t get mine to line up perfectly up there either. No matter what I tried. I’ll one up you too. I can get mine off to even try again! I somehow managed to strip the top bolt so it just spins. Won’t go any tighter and won’t come out. I obviously cranked it down too hard even though I don’t recall doing so. I’m usually pretty good with that sort of thing and if anything I usually don’t tighten enough. That top bolt is in there though and the bottom bolt is perfect. The handle is nice and tight so at least I got that going for me.
What I did since I can’t take it off and that little gap will drive me nuts is I heated it with a hair dryer and shaped it a little better. Didn’t take much and it helped.
I’m just wondering why you don’t put a locking nut on that loose/spinning one ?
***No I’m not being serious***
  • Replies 480
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
