What are the difference between the two years? Bed stack pockets, stake pockets spacing, width, lengths, etc..
I found locally on Craigslist a topper and tonneau cover that I am interested in but not sure if they would work. The tonneua cover is from a 2009 short bed and the topper from a 2010 Short bed crew cab.
I looked up the tonneua cover manufactured and they list a separate version for 2014 using newer mounting hardware on the interior of the bed versus the stake pockets.
Thanks,
I don't think the stake pockets are readily accessible on the new trucks.
Interior bed sheet metal is the same. Exterior (including rail tops) and stake holes are different.
My Roll-Bak bed cover transferred perfectly from my GMT-900 to my new K2 using the same hardware. Can't speak about other brands.
The one on Craigslist is a fold-a-cover G4 Elite Cover & Caddy Bundle | 07-13 GM Silverado/Sierra 5ft 8in bed (GM4924+PC0). For $250, I might try to see if I can make it work if the stack pockets are similar. I did notice the 14 has the bed caps all around versus the earlier one that just had the tailgate.
Maybe contact the company and see if it fits I am sure they will be 100% sure one way or another
Ryan
  • 4 years later...
Might be bringing this one back to life, didn't want to start a new thread...
Anyone else transferred old tonneau covers (2007-2013) to a 2014+ crew cab short box? I purchased a used Roll n Lock of Offer Up and the guy supposedly had it on a 2014+, but when I contacted Roll N Lock to purchase missing parts, they identified that it was for a 2007-2013 truck and it will not fit...a little bummed out if that's the case...
  • 4 years later...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
