Still have HORRIBLE BELT SQUEAL after $1000 and 5 Trips to Firest
jggaddy2
Hi,
I'm new to the forum and I hope someone can help me. I have a squeal that just won't die. It's a 2001 Silverado 1500 with the 4.8 engine.
I'm going try try and lay this out logically in chronological order. About a year ago, I bought this truck and everything was dandy. Great truck, no problems. I then lost power steering one day and had Firestone replace the power steering pump. Since then there has been a terrible squeal. To correct this squeal we have:
1) replaced the tensioner pulley and belt which worked for a short period of time before beginning to squeal again. The squeal started only during turns and then gradually went to a full time shrill squeal.
2) replaced tensioner housing. Same thing...stops for a while then starts squealing during turns, then gradually goes full time again.
3)tried belt conditioner...makes squeal infinitely worse
4)replace water pump and radiator hoses...same thing...squeal stops for 75-100 miles then starts again during turns then gradually back to full time.
Every time Firestone does any work, it works for about 100 miles then starts again during turns then back to full time. Currently, its back to squealing full time. When I start the engine sometimes it sounds at first like when you put a playing card in the spokes of a bicycle. That choppy tat tat tat tat sound. Then that usually goes away and the squealing starts. Always loud squeal and worse during turns.
If anyone has any advice it's greatly appreciated. I want to love my Chevy, but I can't right now!!!
Josh
Sounds like all the parts you replaced are not the one that is the problem. Have you checked every pulley? What about the power steering pulley? A/C pulley and tensioner? The A/C is a separate belt and pulley and tensioner than the engine on my 6.0l.
After reading your post again, I would put 99% of my time and energy into looking at the power steering pump that was replaced.
No squeal before you lost power steering correct? And then you notice a squeal when you turn, and all the time since you have replaced power steering parts? I would look back into that....and Firestone could be the culprit there.
Good luck. Post up what you find out.
@sahls01gmc
Thanks for the advice. I'll keep you guys posted. I'm gonna be going back to good ol' Firestone later this week...
Remove belt and measure power steering pump pulley runout by eyeballing or with a dial indicator. I'm willing to bet the pulley is out of round.
Also check alignment of pulleys across the face. And quit using Firestone
X2
I am betting since to replace that pump the pulley has to removed and pressed back on they F'd it up
Point taken! I'm definitely done with these jokers after I get my money's worth. (if it's not just down the drain at this point) My old mechanic retired so I'm scrambling here in Charlotte!
I'll keep you guys posted...thanks for the great advice.
Its not the brand, it is the people working there, and even at that, it is the person with the wrench. Besides that, when the power steering quit, was the reason for the pump failure dealt with as well? Sometimes parts wear out naturally, and sometimes they wear out unnaturally. If every time they work on it, the noise stops for about 100 miles, what common item or procedure is being done every time? May sound stupid, but, what ever they do every time is in the area of the problem, they are just not getting the cause, they are getting the symptom.
If before the pump was replaced, it did not squeal, then go no further than in the immediate area of the pump. Depending on where the steering pump came from, it may or may not have had the pulley installed by manufacturer. Either way, you need to make sure the pulley is correctly aligned, is correctly installed (not crooked or bent), make sure it is the same size as well. If the pump came as just the pump and reservoir, shop would have had to move mounting brackets over, are they installed correctly? This would likely show up as making the pump out of line with rest of pulleys.
Does the steering work as it should? Could there be an issue with steering box making the pump create high pressure? That also may have been the cause of the initial pump failure, and is why I asked if they found the cause of failure in the first place. I do not know if the 01 GMC had rack and pinion then or not. But either way, the steering gear can cause the pump to vary the pressure applied. Run the steering wheel to the stops and listen, you will hear power steering pump load up.
Have seen this before,the problem is most likely the power steering pump pully depth.its either too deep on the shaft or not deep enough. The misalignment causes wear on the edge of the belt which in turn causes the squeal. Belt replacement is a short term fix and will soon start squealing again.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
