Tire Pressure Monitor Service
Hello all, I got this message on my DIC tonight while driving home. It says to service TPMS System soon. Anyone else experience
this or fixed?
Thanks in advance!
I have the same light on and one of my TPMS sensors isn't reporting. I've purchased another sensor and I'll have it installed shortly.. I'll repost feedback if this fixes the problem.
My 09 does that on occasion but usually after turning truck off and starting again, it goes away. A sensor going bad or interference with the receiver. Cycle through your tire pressures in the DIC and it will tell you if it is a tire pressure not reporting. If it continues and it is on the same tire, probably the sensor going bad.
If you need to purchase a new TPMS sensor, you might want to check out this link. It is at Rock Auto and they have them on sale right now. But check around as this may not be the least expensive out there.
Go to the link and scroll down to the bottom for the TPMS sensors.
http://www.rockauto.com/RSS/vehiclefeeds.php?carcode=3000997&m=wc&l=en&html=true
Autotire has a generic sensor that works well. They have put two on my Yukon for about $80 each. That's about half of what the dealer wanted. They have been working perfectly for over a year.
I posted a link above to some AC-DELCO TPMS sensors. Good price and I believe AC-Delco is synonymous with GM.
$25 each.
that message means there is code to have pulled
this or fixed?
Thanks in advance!
