Can I still get it fixed?
I recently bought an 04 GMC Sierra and the instrument cluster went out. After researching I see this was a recall issue dating back to 2007. Being that this is 7 years after the recall date, and me not having a letter about the recall, can I still get this issued fixed for free at the dealership? Thanks.
Ask the dealer. Can't hurt. Probably will get shot down. Only about $200 to fix your current one
$200 at the dealer or somewhere else?
I don't think there was ever a recall. GM extended warranty coverage on the cluster but that's all I can remember.
Correct. No recall, just extending the warranty period to 7 years. Have heard reports of some dealers still working with owners to replace them, but, iirc, it wasn't totally free. I'd still go the route to have your current one rebuilt or replaced. Several reputable sellers/rebuilders on Ebay
http://www.dallasclusterrepair.com/index.html
http://www.floridaspeedometer.com/Default.aspx
http://stores.ebay.com/BRIANS-SPEEDOMETER-REPAIR-CENTER
http://www.gmgaugeguy.com/Gauge_Cluster_Repair.html
https://www.myairbags.com/gmclusters.php?gclid=CO6Oi7mp0K8CFeVgTAod80nbEA
Or do it yourself. Several how to threads on this site. If you can solder, you can repair it
http://www.youtube.com/watch?v=gWELz904fj0
Summit has a set for 170 plus core. Just fill out the paper work on old set prior to pulling it. And take care with pigtail. I do not endorse any one, I just cared to get it done and not worry about doing the rebuild myself.
I did the same thing and put a 2500 series cluster in mine to get the transmission temp. It was 187, but had a 300 dollar core I believe. It was really fast and really convenient to have it all programmed when it came to me.
Florida Speed (txab has the link in his post above) is who I dealt with on mine when my 03 2500hd went out. I needed a temp guage for the tranny as well for a couple of bucks more. Real easy to work with and super fast! Good luck!!
    mark2
    mark2
  • Who's Online   6 Members, 0 Anonymous, 628 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
