The Table below is a part of a calculation spreadsheet I created to improve my understanding of fuel economy for the LC9 drive train on my 2010 Chevy K1500.
I was unable to upload the spreadsheet so the best I could do is the table below. The websites used:
1. http://www.chevrolet.com/performance/crate-engines/lc9.html
2. http://www.mk5cortinaestate.co.uk/calculator3.php
3. http://www.ehow.com/how_8697811_calculate-volumetric-efficiency.html
4. http://www.mp3car.com/engine-management-obd-ii-engine-diagnostics-etc/75138-calculating-mpg-from-vss-and-maf-from-obd2.html.
The calculator uses all the available inputs to estimate MPG by RPM/Speed:
Engine Displacement, Tire size, Rear Gear Ratio, Transmission Ratios (6-speed) & Air flow rate.
The outputs are RPM v Speed v MPG for each gear combination with Volumetric Efficiency. The output does not include the effect of AFM Cylinder Deactivation, maybe one of you can help me model that.
What did I learn?
1. The most efficient speed is 73 MPH (~20 MPG), I rarely (almost never) get to go that fast.
2. The model confirms that around town driving should yield ~17 MPG.
Questions and comments welcome.
Blue Chevy Pick-Up
6th Gear
RPM MPH MPG
750 31 17.1
1000 42 16.9
1250 52 16.8
1500 62 18.2
1750 73 19.9
2000 83 16.6
2250 93 16.4
2500 104 17.1
Using the DIC in my Sierra and using Instant MPG on my daily drive up I-71 for about 30 minutes I have found driving 70-73 MPH, I get 18 to 13 MPG depending on wind and the grade of the road. Going up hill it get less than on flat land or going down hill. A strong head wind or side wind will decrease overall mileage usually below 15 MPG.
I don't know how scientific this is or how is compares to your algorithm but it make sense to me.
Karl
I don't have the benefit of a DIC display as the dash & interior is very basic. It's no surprise head winds and hills make a big impact on fuel economy. The model was tuned to the ~20 MPG that really did happen on a ~75 MPH drive from North Carolina in January.
Thanks,
Blue Chevy Truck
Since aerodynamics also plays into this, and we have 6 gears in these transmissions now, I would take a look at various RPM's and speeds in 5th gear. There is no government or manufacture mandate that the top gear always be used. The 18 speed in my commercial truck hasn't ever been in the top gear since I bought it new 237,000 miles ago, and it has seen speeds of 85+ mph several times.
Aerodynamics have a negative effect on a rising curve as the speed goes up, especially above 55 mph. And there are instances where lugging the engine at say 1750 RPM would have a negative effect on economy compared to running 2100 RPM. Load on the engine plays into this as well. And rotational inertia plays into it. At lower RPM's, the engine may be fighting rotational inertia more than at a slightly higher RPM.
There are just too many factors that can effect fuel economy to narrow it down to a spreadsheet. It is fun to play "what if" games with this kind of stuff, but it takes some very serious processor time on a heavy hitter computer system to model all the various aspects that affect fuel economy.
Rear end ratio also plays into this. Are you basing your assumptions on a 3.08, 3.42, or what? Must be 3.08, as 3.42 at 1750 RPM with the 6 speed trans and factory rubber yields about 68-69 mph.
Was looking at the first link and playing with the slider and watching the gauges move. Interesting that the chart shows max torque at around 340 ft lb, but the gauge goes well over 400 ft lb when one moves the slider.
I have the 3.42 rear, as the table indicates, the truck goes 62 MPH at 1500 RPM. I've often wondered if I couldn't get better MPG by driving in 5th gear (M-mode) and forcing the throttle into a higher volumetric efficiency.
I will generally run in M5 on everything but 4 lane freeway, where I will let it kick to 6th. Main reason is that when in 6th on hilly stuff, it constantly is hunting and searching for the gear to get it done. Seems like every little molehill causes a downshift to get over the rise if the vehicle speed is below 65-70, or loaded at that speed or even a little higher. And that shifting will eat fuel like crazy. So I will run in 5th on anything below 65 mph and greatly reduce the shifting. I have found also, that even at speeds like 65-70 on the freeway, when the wind or a load is really making the engine work, it can get a mpg improvement by running at the slightly higher RPM of 5th. Reason is that at the lower RPM it actually takes more throttle to get the same job done and also that there is some rotational inertia that the engine is fighting against as well. EGT's will tend to rise higher at hard working lower RPM's which reflects an increasing restriction in the exhaust stream due to exhaust cooling along the route to the tail pipe. By increasing the flow with a little RPM, you are actually decreasing the workload on each cylinder by overcoming some of the rotational inertia, and getting the exhaust to flow a little quicker and get further down the line before it cools significantly to cause a bottle neck.
I gleaned all of the is stuff from working commercial diesels for several decades, and it seems to play out very similarly with our smaller gas engines. Principles pretty much remain the same. This is why I usually make the point, that the driver has more control over fuel economy than any mod ever could. Studies have shown the driver accounts for well over 1/3 of fuel economy variance. And this is even more pronounced when using tall ratios like 3.42 and 3.08 in the rears. You have to do more of the thinking for the engine. On a nice flat grade on a calm day, everything does as it should from the factory. But throw anything else into the mix, and things get screwed up. The ECM cannot read terrain, wind, and other factors. It just knows how to go and it will do whatever is programmed into it to make the vehicle go. If it feels it needs to downshift and floor it, it will. Yet another reason that I will remain off the cruise control on everything but 4 lane interstate/freeway running. I can see the terrain and the conditions and moderate the accelerator better than any ECM ever could. On the freeway loping along, there is a decided advantage to cruise control, unless someone is under a heavy engine load.
  • 4 years later...
What did I learn?
Blue Chevy Pick-Up
6th Gear
RPM MPH MPG
750 31 17.1
1000 42 16.9
1250 52 16.8
1500 62 18.2
1750 73 19.9
2000 83 16.6
2250 93 16.4
2500 104 17.1
1st and 4th links are dead now, did you save them by chance?  How have your real world numbers stacked up against the model?
    HWN808
    HWN808
  • Who's Online   5 Members, 1 Anonymous, 943 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
