Stake hole pocket covers?
So this is at the end of my bed and I am wondering what you use to cover it? I don't want it exposed and collect snow. Why did they even leave it open?
Truck Bed
  • Replies 43
It is opened larger than before because it acts as a secure hand placement when entering the bed from the cornerstep. No cover that I know of/have seen other than a tonneau cover.
I was looking for the same thing online yesterday
You found any? The ones I could see were for a standard square hole while my truck has a funky design which kinda doesn't make sense.
The opening is larger & angled so you can use it as a handle when stepping up on the tailgate. I've found mine quite useful. Others may not agree.
No i havent found any yet. Same boat as you
Until you find something made or that specific purpose, if there is something, then you could always just wipe around the area and then take some pieces of aluminum from the local hardware store and stick them down with 3M tape. Or if you have the handyman skills and the proper tools you could remove the bed rail protector, draw an outline of the whole onto a sheet of aluminum (or plastic or any other solid material that you can make very thin) and then cut a sheet of the aluminum thin but also make it slightly larger than your markings, and place it over the hole but inbetween the top of bed rail and the protector. Therefore the protector will hold it down and the hole will be covered. Or you could just 3M tape the piece you cut out on top of the hole. I would go one of those routes if I didn't want snow in there, hell, down here in LA I wouldn't mind some snow. And I mean real snow. Not the solid ice we have fall every few winters.
It will not collect snow. It is open at the bottom of the bed panel and will drain out beneath the truck.
It will. There is a small opening on the bottom but not enough unless the snow melts. Im going to look around till fall and if nothing comes up then I will fashion some out of thin strips of aluminum to cover it in the winter.
  • 3 months later...
Has anyone found the stake hole covers for the 2014 Chevy Silverado 1500 yet?
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 524 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
