Just wondering is there a way to find out if you have all or newest updates on 2014 without going to dealer?
Usually if someone finds out something, the post it.
Unless you have a tech2 (gm computer scanner) then no
I completely misunderstood. I took it as constraints, recalls, tsb's and so on
Tech 2 is useless on a 14 model, you need an MDI and a laptop with GDS2
Sorry about that. Basically it still falls into the you need to see your dealer.
Ryan
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 668 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
