Anybody else's shocks shot?
My 2010 silverado started making a clunking sound when I hit a bump. It appears to be coming from the rear. I can hear it when I jump up and down on the back bumper. I looked underneath and can't see anything thats come loose but I can hear a gurgling sound coming from one of the shock absorbers. They aren't leaking but one is definately making noises. The truck only has 43000 miles on it but I'm thinking the extreme cold this winter may have caused it to fail.
Anybody else have shock problems this early? What do you guys recommend for replacements? Right now it rides pretty rough and I'd like to smooth it out.
....Anybody else have shock problems this early?
Not here. Easy enough to disconnect shock bottom bolts and see how (if) they are functioning.
I'll check it out but 43K sounds like a little early to have bad shocks don't you think?
Bilstein 5100 series for replacements. Best shock for the money hands down.
My aftermarket pro comps are only good for 30,000 the vendor told me that so it's not uncommon. And +1 on the bilsteins
sent from my truck in a field
Your shocks could be junk. There are so many variables that can affect them. Did you tow alot? carry heavy loads? are you roads where you live realy ruff? I have heard you should change them around 50k so your not that far off in my book especially if you do any of the things I mentioned. My truck has 43k on it also and I will proabably be changing my shocks sometime later this summer.
Parts life is all relative, so 43k can either be too many or not enough miles depending on use and terrain.
And if the OP wants a smoother ride for light duty use, 4100's would be best imo. That's what I'm aiming for sooner or later.
Is it a Z71? Either way I'd go to Bilstein for replacements, they make awesome shocks.
It is a Z71 and I rarely haul anything except my dog, a dirt bike, or snowmobile. The only thing I pull is a loaded four place snowmobile trailer so I suppose that puts a little weight on the rear but not excessive. Our roads in ND are pretty rough right now with all the frost heaves coming out. I also drive about 3000 miles a year on washboard gravel roads. So I suppose the combination of all these things caused the failure but I made it 57K with my 07 and never had a problem. Maybe they cheapened up the shocks a little on the 10's to save a few dollars. I was looking at the Gabriel ultra shocks but if the Bilsteins are that much better maybe they are worth the extra $??? Are they that much better? Ride smoother? Last longer? What is it?
With what you just described I am not surpirsed you shocks are toast. Just think of the abuse they are seeing with your snowmobile in the back of your truck driving down roads with frost heaves. That has to weigh atleast 800lbs if not more. Also I bet the 4 place trailer has some good tongue weight on it.
I would also recommend the Bilsteins.
I know what you mean about the gravel. Roads here get really rough, fortunately I don't have to drive the really bad ones much any more.
The nice thing about Bilstiens (at least the 5100s) is they provide more stability at speed. I've noticed the truck handles whoops better too. On washboards you may not see much difference. It will still be rough lol. I did notice that in super rough places like where the truck bounces sideways when you try to accelerate, they seemed to help. I have heard good things about about the ones you mentioned too though
Had to get new shocks for my truck, though since I bought it used I have no idea how many miles they had on them, I'm assuming a lot. Bought some Monroe shocks, can't remember exactly what they were called(couldn't find the receipt), its what the shop recommended. Were kinda expensive(about 100 bucks a shock) but are supposed to be pretty heavy duty and with as few miles as I put on my truck, I should never have to replace them again just as with the tires. One of my old front shocks was so worn out that it was actually leaking fluid. I could have just replaced both front shocks but decided to get 4 new ones as I assumed the rears weren't much better.
Ok I ordered the Bilsteins (spelling?) 4600 which I believe are the standard height replacements. Stopped in at CarQuest today and they sell KYB's but they were more than the Bilsteins. $94 plus tax for the rears and more for the fronts. I bought four Bilsteins for $337 with free shipping from Shock Warehouse. I didn't think that was too bad. I can't wait to switch them out. I can do the rears myself but not sure about the fronts. Are the fronts a big job? Do i need special tools?
Thanks to all of you for your advice!!
Oh yea, I forgot to mention I noticed today that one of my front shocks was leaking. Still seems like they should last longer than that.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
