Bed Rails
I'm guessing your talking about the chrome or black cylindrical rails. The pic above is of the rail caps, that all of them have. There is a truck near my work with black ones, it looks pretty good. He has black steps to match.
  • 3 weeks later...
Is there any company out there making these for the 14"?
I found them on the companies site that made that truck for sema. I think I was searching headache racks at the time.
It was awhile ago so I can't remember the company or site
If I get some time later I'll see what I can come up with for you
That does look sharp! I would like to know more about it.
There are a buch of references to it as "Black Ops", a GM concept truck introduced T SEMA 2013 as if it was entirely custom by GM. Hmm?
2013-SEMA-Show__43_-LineX-2014-Chevy-Sil
Sorry this was the one I was thinking of that I found for sale
That **** looks way too Black OP for me.. I like the other one better.
I might have to fab one up myself.. :D
Yes I agree, way too much. The one you posted is much cleaner
hey anyone put the putco locker bed rails on their trucks? looking to order them but wondering if it was worth the money or just get a cheaper brand? any advice or opinions would help thanks
  • 4 weeks later...
Does anyone have stainless or black bed rails installed on a 2014? If so pics please!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
