I have a 01 1500 HD (154,xxx miles) and as long as I can remember my engine ran at about 210 (right below it). However this week I noticed it was running at at about 180-185f (. It would stay at that temp on streets or highway driving. So, yesterday I replaced my thermostat with the 187f therm which is what comes from the factory. However today it got up to 210 then dropped to 185 or so and stayed there.
How come it is running cooler now when it has always ran a hair under 210f? The only thing I could think of is maybe the coolant temp sensor is bad but IDK.
Here is where it runs at now(red line) and where it used to run (stock needle)
I could be wrong, which is always possible, but I thought the stock thermostats for these trucks were 195*? Don't know why that would make such a difference but I think you may have gotten the incorrect temp rated thermostat.
I accidentally bought a lower temp stat and it did that. The only possible negative effect would be very slightly lower mileage as temps would be lower. You really need to get a scantool that can read live data to make sure the gauge isn't inaccurate.
+1
+1
Unless you adjust your "on/off" temperature of your fans (ECM adjust) it does not matter what temperature the thermostat is, the water will heat up to the prescribed temperature the fan is programed to.
The therm I pulled out said 86c which converts 187f
Why did it run at a lower temp with old therm(for a week or so) and new therm?
This is true, but since he only replaced the thermostat, why is it now running cooler with the same program but new thermostat? That's what's got me curious.
Except for the fact 2001 models do not have e-fans..........
187 is the correct therm. 195 is the operating temp. 187 is just the temp where the thermostat opens to let coolant circulate
Why did it always run hotter til now with new therm???
That one I cant answer. When searching for new thermostats the factory replacement I find is 187.
The only thing I could think of is maybe the coolant temp sensor is bad but IDK. I am little concearned only because I am heading up the Cajon pass to Barsrtow towing about 1500-3000lb in my utility trailer on Memorial Day weekend
The only vehicle I can reference is "Sara" (2001 Camaro Z28) and she DOES have "e fans". I to installed a 185F thermostat in her, and when I had a dyno tune (for other matters), I had the tuner set the fan on/off speed to correspond with the lower thermostat.
Running slightly cool is fine. That pass isnt that bad for your truck and only towing up to 3000 pounds. There is a lot worse in the area thst I can think of.
Thanks for the input Chris. Btw, I'm heading to Barstow(Slash x area) to go riding in a few weeks and just want to make sure my truck is running up to par
Edited by 1500HD Todd
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
    • The cure for facism. https://imgur.com/gallery/cure-fascism-9DH3bHs
